Blower Scoop Exercise
kegan_king
Posts: 7 EDU
I'm struggling with step 20 of the advanced loft exercise. I have rebuilt the model twice now and I'm am still unable to see what I have done wrong that will not allow for the shelling of the scoop.
any advice here would be excellent.
https://cad.onshape.com/documents/09e1ce1c4522bfb05ececc38/w/dde8c894bfa725c27e973574/e/c5a93ebe94f02cfb5a0a1b76?renderMode=0&uiState=61b531a784430a4aa4453f69
@kegan_king
it looks like there might be something wrong with either the loft or the split. I would double check Step 16 to make sure you selected the correct start/end profile conditions and Step 19 to make sure you split the part correctly.-1 -
I checked it and it's
as it should look in the tutorial 0 -
@kegan_king
the loft image does not show your dialog selections.0 -
Could you edit the shared document so that I can copy it to see the actual selection?kegan_king said:I checked it and it's
as it should look in the tutorial0 -
@kegan_king
Thank you for bringing this to us! We have identified an update in the loft feature which now causes this exercise to fail at the shell. We have marked this as a bug on the exercise and will be updating it.1 -
COOL! I knew it wasn't me. I rebuilt that model like 6 times it's was maddeningly frustrating0
Did you guys resolve the bug I would like to complete the model. I attempted to today but no dice...KatieHuffman said:@kegan_king
Thank you for bringing this to us! We have identified an update in the loft feature which now causes this exercise to fail at the shell. We have marked this as a bug on the exercise and will be updating it.0 -
@kegan_king
Still working on it! Stay tuned! I will attach you to the ticket so you will be notified once updated.0 -
I have the same issue.
it's a bugjohn_willden said:I have the same issue.0
