Exporting to JT 10.7
pete_rimkuspete_rimkus Member, Developers Posts: 4 ✭✭
Hello,
The documentation says that Onshape supports import/export of .JT files up to JT version 10.7.
Is it possible to control what version of JT a part gets exported to?
There is not a version dropdown control in the Export page when JT is selected, and after downloading, I see that the resultant JT file is from JT 9.5.
Thanks in advance
Pete
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,991 image
    There are no export options for JT. The help docs are probably wrong. Exporting to an older format version should make it more compatible with more systems?
  • pete_rimkuspete_rimkus Member, Developers Posts: 4 ✭✭
    That is true, but other exporters do have a 'version' option in the export dialog.
    Is there a way to elevate this as a request?
    For 3D, we only allow Parasolid version export - what will you gain from exporting JT in that particular version?
