How to create a circular pattern that doesn't not axis around the orgin point?
geo_thampan
geo_thampan Member Posts: 4
edited January 2022 in Community Support
I need to create a circular pattern that follows a circle which created in a sketch. But when ever I try to create a circle pattern the selected sketch follows an axis around the orgin point. To experiment I tried this outside the sketch in parts feature, which works, but it is not helping. I need to create pattern wich has my preferred axis point. Can axis point in sketch for circular patter be selected?
  • john_mcclary
    john_mcclary Member, Developers Posts: 4,100 PRO
    Yes, a common mistake people make with circular pattern is they forget the center point is NOT attached to anything.
    The indication is the fact all the lines are blue (which means underdefined)
    Once you have everything fully constrained then all the lines turn black
  • geo_thampan
    Wow! Just so simple. Thank you so much Mahir!
