The drawings are not generating
mario_darceuil
Member Posts: 113 ✭✭
Please look at the tag below and see that it is not generating, I don't think my MAC is the problem. Please help.
Gee i thought i extruded them to 1/16 or 1/32 inches decimal.Thanks. I created one fin and used the linear tool to get the others. Do i used merge or make coincident with the tube to attach them?-1
That's because you made the fins from surfaces that have zero thickness and are not attached to the tube - you need to create thin solid extrude features.Senior Director, Technical Services, EMEA0
Just use the “add” option in the extrude dialog.Senior Director, Technical Services, EMEA1
