How can I get OnShape to make 'different' line selection?
john_smith077
Member Posts: 175 ✭✭✭
Hello
When selecting lines for some operation (e.g. when I am doing some Chamfering), OnShape keeps making the wrong line.
Is there any way to get OnShape to select a different line to the one that it selects by default when you first do a mouse-over action?
I keep having the problem that I need to select a short line, that is in exactly the same place as a longer line, and I can't work out how to get OnShape to highlight the line that I want.
Thanks
J
Thanks
J
Use "Select other" in RMB menu or by pressing key above the tab key.Senior Director, Technical Services, EMEA0
Right click and click "Select other"
Classic.. Didn't refresh the page before answering.2 -
A bit clunky... but yes that works.
Thanks
J0
