How to pattern sub assembly in Onshape Assembly?
team_esc
team_esc Member Posts: 4
  • Narayan_K
    Narayan_K Member Posts: 379 ✭✭✭
    @ team_esc, At this moment we don't have assembly pattern option in Onshape.
  • andrew_troup
    In some instances, the things which would be done in an assembly in a traditional MCAD modeller are better done in a Part Studio in Onshape.
    Often the litmus test is whether the parts move relative to each other:
    If not, it may not make sense to build an assembly.
  • 3dcad
    3dcad Member, OS Professional, Mentor Posts: 2,482 PRO
    @team_esc  Assembly mode pattern is highly requested feature and it is under development together with other automation to quickly assemble things together.
    //rami
