Updating a part in assembly
ehsan_pazooki
ehsan_pazooki Member Posts: 52 ✭
Hello guys,
I'm trying to update some parts in assembly. But it does not work.
The blue-white update button on top right is not active.
When I double click on the part and the click on the option "update and make new version", this also does not work.
Could some one please help me?
Thank you very much.
Best regards
Essi
    It's hard to tell what the issue is because it requires making a copy of all your docs. The better option would be to make the edit in the part doc and create a new version there, then go back to the assembly doc and then update.
    However, with such a simple assembly i would recommend doing it all in the same doc and then you won't have any update issues. Click the + icon bottom left to create a new Part Studio.
  • MichaelPascoe
    MichaelPascoe Member Posts: 2,960 PRO
    We should be able to help you with this. Can you please provide a link to your assembly.
  • ehsan_pazooki
    Hello,
    Thank you for your reply.
    Here's the Link of my assembly:
    https://cad.onshape.com/documents/8d2c3e31fd2f96acbe986333/w/e004d17603cdbe02c009b92c/e/b89fb6d051a3a728fdbce408
    Best regards
    Essi
  • ehsan_pazooki
    Hello,
    any body there? =)
