Equation Driven Curve in Sketch
jem_q
Member Posts: 4 ✭
Hi, Wondering if the Onshape team was working on a equation-driven curve tool with which you could plot parametric curves within a sketch.
example:
y^{2}=4ax
So that this curve can be created in sketch. Thanks!
Thanks.
example:
y^{2}=4ax
Thanks.0
Add this to your toolbar https://cad.onshape.com/documents/578ff8b3e4b0e65410fcfda3Senior Director, Technical Services, EMEA3
Mind you, this FS creates a curve feature/body, not a sketch curve. However, you can Use/Convert the resulting curve in a sketch.1
