I cant figure out how to import a part into design studio....I dont want an assembly
I'm in part studio and i want to import another part created (below) into part studio so I can work on both...I don't want an assembly as I can't do the same things....HOW do I import that 2nd part
  • matthew_stacy
    matthew_stacy Member Posts: 489 PRO
    @tim_ocallaghan, "Derived Part" is the tool that you are looking for.  And then use the "Transform" tool, if needed to correctly position the derived part.
  • eric_pesty
    eric_pesty Member, pcbaevp Posts: 2,887 PRO
    edited August 2022 Answer ✓
    thanks so much I would NEVER have figured that out....
    You really should consider going through the "Onshape fundamentals" training...
    You'll learn all about this and lots more and will get a lot more out of Onshape, well worth the time as you will be able to do things a lot faster after that.
  • matthew_stacy
  • tim_ocallaghan
    tim_ocallaghan Member Posts: 7 ✭
  • eric_pesty
