Part studio stuck on "Loading studio data"
I can't seem to load a fairly simple part studio. The problem seems to be because of a custom feature (ThreadCreator, probably), but I can't edit the part studio anymore, as it just doesn't load. All the drawings and other part studios still work, except for assemblies containing the part that isn't working.
The document is this: https://cad.onshape.com/documents/beea417a54f3885801294c80/w/323560173740855117708ea8/e/2f569ebafcb4057bb816d4cc
And the part studio in question is "case"
    NeilCooke Moderator, Onshape Employees Posts: 6,115 image
    Hi @nandor_vaiko497 unless you are going to 3d print this thing, there is no need to model the threads in 3d.
    From the documents page, right-click your document and select Versions and history, then select case::Edit:Hole 2 then click the gear icon on the right and "restore to main" - this will open the doc before the rogue m1.8 feature
