Named View w Perspective Turned On
Alexandre_WamainAlexandre_Wamain Member, csevp Posts: 16 PRO
Is it possible to create a named view with perspective turned on such that I could add that view to my drawing? Upon testing this myself I found the named view I created isn't selectable within the drawing. Creating a view from the same angle with perspective turned off did work.
  • PeteYodisPeteYodis Moderator, Onshape Employees Posts: 567 image
    @Alexandre_Wamain This is not supported yet.  I've created a support ticket for you and will place you on the desired improvement.
