How do I stop extrude "Up to part" regeneration errors?
george_sweeney
Member Posts: 5 ✭
I'm having an issue with a design I'm making. The extrusion labeled "medium diags", I wish to extrude sketch 8 up to the extrusion labeled "short diags" but it informs me I have a regeneration error and that I should check my inputs, yet this same sketch has worked on several other planes and has no issue extruding blind. Other extrusions on this part studio have had no issue, including ones extruding through one part up to the one selected such as "rear vert" and "bottom for-aft tubes".
Is there a way to rectify this and any good practice I can incorporate in future to prevent it happening again?
Cheers
https://cad.onshape.com/documents/d1d95e5b8fe95691bd68e09d/w/f423344d43f00d6cd57e124a/e/50ceec6974f6bb2ef12859c8
Cheers
You may want to spend some time to become more proficient with sketching. Included is a sample using an array of sketches for the main end frames then join the dots with 3D fit spline.(spline with 2 points and no weighting at the ends is a line)
Next step is the frames function which can be found as coarse in the learning center. Much more robust and a big time saver.
https://cad.onshape.com/documents/12b0679a712bc6f544f72c07/w/67e973d9c8c7d9393a467fa0/e/43ce3f81443d647d596a0b9a
Cheers George0 -
Thank you for the pointers Glen, I'll give it another try with a different approach.
Yes, you are definitely doing this the "hard way". The frame feature would make this way faster!0
I could certainly stand to break the habit of drawing it how I'd build it!
