Material library for simulation
Adam_Micha
Adam_Micha Member Posts: 17 ✭✭✭
Hi,
To use the simulation functionality it is of course important to have the correct material properties.
We can see that it is possible to add this manually now (previously it was only category, name and density that were supported) but is there any pre-defined material library that can be used or must all this information be entered manually for each material now?
    The material library was updated at the same time so all the info is there in the Onshape Standard Material library.
  • Adam_Micha
    edited November 2022 Answer ✓
    Oh right. Is there any way to edit this? The old style material library was just a CSV and the new one lacks some of our common materials.
    EDIT: Now I found how to get to this. It was an issue of PEBKAC.
  • Adam_Micha
