Gear and Chain/Belt Tutorial
brandon_rogers363
Member Posts: 2 ✭
Just getting started with OnShape and I'm trying to make a simple gear to gear assembly with a chain or belt link. Can anybody point me in the right direction of a video tutorial for how to do this? What I've found on YouTube doesn't go through the full process. Thanks!
There is a feature script called belt. Add it in custom features. Make sure to add the correct one with the belt icon otherwise you might just get a copy.
https://cad.onshape.com/documents/b6f55fd653b05ecf01b8d88c/v/ad44398e3a5a72808bbbbe9d/e/0f7c9f3a22f0d1c622cb71aa
If you want to go further and animate it check out the Advanced Assembly Motion in the learning center.
In the case of animation you wouldn't be able to animate the belt but if you wanted to animate a chain I'm sure it's possible.
This is the official Belt feature https://cad.onshape.com/documents/57886eace4b0e425c1ef548aSenior Director, Technical Services, EMEA0
