Thread wont generate
stephen_dewing
Member Posts: 24 ✭✭
Does anyone know why the thread won't generate in this model?
https://cad.onshape.com/documents/4b70c22d064042dcb4a84570/w/672c84848bd260f8730e4a16/e/5f4e0562e6edf5b1b8fbb3ee
Thanks,
Stephen
Thanks,
Stephen
It's because your hole is not parallel, it tapers slightly since your revolve line is slightly off
you need to constrain your sketch better. There should be no blue lines.
To fix this right now, just make this line vertical.
-Select the Line, then press the letter V to add a vertical constraint
then close the sketch
2 -
Thank you so much John. It has driven me crazy. Such a simple thing. Great advice about restraining the sketch. Very much appreciated.0
2 -
