How do I reference a configuration column in a drawing?
I would like to be able to display the number of teeth in my drawing when updating the configuration
  • MichaelPascoe
    edited December 2022
    There is not a direct way to do this that I know of. However, it is possible to control the "Description" property of those parts with your configurations using Set property - custom feature. Let me know if you need some help with it.
    John and Raj have the better approaches for this ⬇️
    RENDERCAD
  • You can also just set the tooth count to a configured property. You can see the tab on the top of your first photo
  • You can use computed custom properties to propagate "Number of Teeth" to a custom property and then use it in the drawing
