Frame Name Change
I'm looking for a way to change the names on the Frame Parts in the cut list. I was wondering if there is a way to copy the ANSI Frame profiles and change their names to better match the company's part numbers or, is there a way to edit the Cut list besides adding an override to each frame?
  • wout_theelen541wout_theelen541 Member, csevp Posts: 200 PRO
    As far as I know you can't really change standard content names. You could create a separate document with instance of the frames you use and create sketches from these instances.
Howdy, Stranger!
