How do I delete a single part studio from a document?
nick_lumb
Member Posts: 26 PRO
Sounds embarrassing to ask this but I have spent too long looking :-)
I can delete a document and I can delete a part from a part studio but can't find (in help or forum) how to delete a part studio.
Or use RMB menu on tab and select delete, this works for active or inactive tabs (part studio, assembly, drawing...)
//rami5
you can delete al but he last part studio by right clicking the part studio tab and pressing delete.
//rami5 -
As @ 3dcad, said you can delete the part studio clicking RMB on the tab and click delete.But you will not get the "delete" option if there is no any other part or assembly studio in the document.because it is equal to deleting a document.nick_lumb said:Sounds embarrassing to ask this but I have spent too long looking :-)
@nick_lumb , You can delete any "tab" in document by following method suggested by @3dcad . If it is not deleting then there will be two chances.Narayan_K said:
1) In that document only one "tab" is there which you want to delete. It won't delete because it is equal to deleting a document as suggested by @Narayan_K
2) You shared that document with other user and might be that user working on that tab. In this case you can not delete that "tab"
@joris_kofman One more suggestion. If you delete any tab, to restore it back you can restore from the history. But you will not able to restore it by undo as proper workflow is to restore from history.0
I can't believe I didn't try RMB but clearly I didn't. Thank you all :-)0
