Drawing - Cutting plane using ISO 128
Mr_Devisme
Member Posts: 6 EDU
Hi,
I can not find the option to use the arrows of a cutting plane following ISO 128
You have to choose an ISO drawing format to see this style of section line.Senior Director, Technical Services, EMEA1
Thanks for the quick reply - Could it be that this only shows up using the First Angle projection? I am using ISO and Third Angle and the arrows are pointing the ANSI way
Huh, you're right. Supporting all drawing standards like BS8888 has been on the todo list for a long time. Please create an improvement request.Senior Director, Technical Services, EMEA0
Thanks, improvement request submitted
