FS Box joint; Why maximal 12 pins?
DI_PE
Member Posts: 7 ✭✭
@NeilCooke,
I like to use more than 12 standard and dovetail pins with your FS Box Joint. However, is it correct that the limit is 12. Is there a reason for that?
It was only there so that if you accidentally typed a very large number you wouldn’t have to sit there while it regenerates. I’ll change it to 200.Senior Director, Technical Services, EMEA1
I have absolutely no idea it was so long ago. I can change it though.Senior Director, Technical Services, EMEA0
Increased to 24 hope that's enough.Senior Director, Technical Services, EMEA1
@NeilCooke,
In the configurable box that I made I had pins of 8 mm and edge lengths of >399 mm, which needs >24 pins.
So, Is there any limit needed and why? In other words: can the limit be removed?
