Extrude a sketch at an angle?
mike_klaus149
Member Posts: 2 ✭
I'm trying to draw legs of a 3-legged stool. The legs need to come out of the bottom of the top at a 5 degree angle. I can't see any way to tell Onshape to extrude a sketch at an angle. I don't want a draft, I'm not looking to flare out the legs, I just need to extrude them at a 5 degree angle. Is there any way to do this in Onshape?
A round or turned leg profile could be created from a single sketch on one of the native planes with the revolve feature and then circularly patterned for the other two. You can create the sockets in the seat with the same approach. Square leg profile, do what @S1mon says.0
https://cad.onshape.com/documents/df4332164c7e89b467d9d808/w/d16081a7b69c301bbc6ae423/e/5f002e4f7fb60c8ac0cbbc42
Feel free to copy and see how it is done.
Note that you can save also use a mate connector to directly define your sketch (and skip "sketch2" and the plane shown in @dirk_van_der_vaart example):
https://cad.onshape.com/documents/c6ad948523057b7e83429105/w/a1b2354ef3a0e2b2d3718d7a/e/cde6bf1b37a3f50ba3f31809
You could also wait a few days......Senior Director, Technical Services, EMEA5
@NeilCooke
You tease.Simon Gatrall | Product Development, Engineering, Design, Onshape | Ex- IDEO, PCH, Unagi, Carbon | LinkedIn
1 -
Is this the elusive "sneak peak" of an upcoming improvement?! You mean tomorrow rightNeilCooke said:You could also wait a few days......
1 -
Sayin' nothin'eric_pesty said:Is this the elusive "sneak peak" of an upcoming improvement?! You mean tomorrow right
Senior Director, Technical Services, EMEA1 -
I keep hitting refresh but not seeing anything... It's only 4pm so there's still time but still... The suspense is unbearable!NeilCooke said:
3 -
I literally can't...NeilCooke said:You could also wait a few days......0 -
ahem... you may now refresh...Senior Director, Technical Services, EMEA4
