Exercise: Bearing Load
I just did the bearing load exercise from Introduction to Onshape Simulation.  I'm not getting the correct answer, and when I opened the completed document to see what we did differently, they don't have the correct answer either.
My document - https://rit.onshape.com/documents/d85380680738f5ba2988b73f/w/dffc660453df664d31bec8aa/e/15bf4540cf8b14bc70d85e47?renderMode=10&uiState=63ea4646e3619a3054a2ab60
I get "Sorry, not quite. The correct answer was 6.781e-5 inches. You may refine your model and try again. To see how we did it, make a copy of this public document."
But the Solution - https://cad.onshape.com/documents/8a68fe52debccddc387550f/w/7698ecded69345e28181b293/e/0a7c3cadd20f490dbc759d7c#_ga=2.32974974.136480594.1676296354-422416952.1581082985 gets a smaller value as well.
  • KatieHuffman
    KatieHuffman Member, Onshape Employees, Developers Posts: 194 image
    @kate_leipold_rit
    Thanks for bringing this to our attention.
    After closer inspection of this exercise, we decided to modify the model set to make it more clear how to define a Bearing load, and provide a more repeatable set of steps to ensure a consistent answer with less ambiguity in the design and setup. We have updated this exercise completely, please see it in the course live now.
  • KatieHuffman
    @kate_leipold_rit
  • kate_leipold_rit
    kate_leipold_rit Member Posts: 43 EDU
    I just completed the rocker arm exercise and everything was smooth.  Thanks!
