First time . Created Project but Toolbar doesn't have Rectangle or Circle or Line. How do I turn on
dave_burch
Member Posts: 3 ✭
"F" for fit is another handy quick key.
I'd suggest doing some tutorials to get going.5
You start by inserting a sketch on a plane (should be the first icon after the undo/redo). Then the sketch toolbar will come up while the sketch is active.
https://cad.onshape.com/help/#simpleexample.htm?TocPath=Modeling%20in%20Onshape|_____1
tip: if you press "N" you will get a view normal to your sketch.
THANKS. HAVE GOT THE CIRCLE ETC. drew the circle I wanted. But the circle line toolbars go away and I have to do the N again each time I want to use them. I will practice for a few hours and see if I get better.
I'd suggest doing some tutorials to get going.5 -
Yep I am plowing thru the Tutorials now and its a better way, Thanks again0
