How to create a negative form with an offset
jonathan_jensen215
Member Posts: 4 ✭
Hi everybody,
im currently working on this file:
https://cad.onshape.com/documents/ceaa5a6876b72ad7235fe994/w/469e535b0afca0891a6b0a7a/e/2ae7080bd6d9d0cba431141a
It’s an form for an iPad and a pencil. I want to 3d print that part and a negative and then sandwich wet leather between both parts to form the leather. To do this, i need an offset of 1.5mm in the negative form and i can’t figure out how to do that.
Matt_Shields
Member, Onshape Employees Posts: 957 PRO
You're in luck. The Boolean tool has an offset option built in!
1 -
eric_pesty
Member, pcbaevp Posts: 2,686 PRO
Create a new solid for your other part and then use a boolean to remove the current from it, you can add an offset in the boolean command or if you only want some of the faces to be offset you can use a "move face" feature.
EDIT: something like this?
https://cad.onshape.com/documents/e5e3c3e7b2cfa57b33e56645/w/fe9ef50e55444bed8cecabba/e/8d95c3c1d039b24857813546?renderMode=0&uiState=641df248bb0cab19bbdd775b
