configurations
Hi,
I've been reading up on a lot of discussions relating this issue, but haven't really come across a solution for this challenge.
Is there a way to set a value for a global variable in variable studio using part or assembly configurations?
I have a model (part)  set up using these "variable studio - global variables" (having the variables listed up in a studio being neater than "loose" variables in the history browser of the part studio being the main reason to do so)
Now I don't seem to be able to load these variables with a different value from the configurations, something that can be done when using local variables confined within the part studio.
I am probably missing something here. probably to do with hierarchy?
If for some reason above is not possible, can I convert the list of "global" variables in variable studio back to "local" variables within the part studio, which I can then control by the configuration.
Thanks in advance!
Regards,
Steven
    NeilCooke Posts: 6,097 image
    They are global so they trickle down. You can only configure local variables (and you'll have to copy them local first).
    Manually I’m afraid.
  • jr_vrvrkn
    jr_vrvrkn Posts: 125 PRO
    Ok. clear Suspected something like that alleready. one more question: how can you "copy" them?
