Features hidden by extrusion
msandeep
msandeep Member Posts: 16 ✭
I am trying to extrude features originally drawn on Top plane, but now hidden by an extrusion. I am unable to select these features. Is there a way to "hide" the first extrusion so that I can select the hidden features?
https://cad.onshape.com/documents/c33a79fdba921323df324d25/w/d34920b58156294bd53f27b1/e/a2171abb1d27916119221368
  • Matt_Shields
    Matt_Shields Member, Onshape Employees Posts: 986 PRO
    Keyboard shortcut for Select Other is the ` key (usually to the left of the number 1 on your keyboard).  I use that a lot.
    NeilCooke Moderator, Onshape Employees Posts: 6,103 image
    • If you're trying to cut the grey part from the blue part, use boolean subtract.
    • If you just want to select the sketch areas, use select other (right click the area)
    • You can hide one or both parts using the eye icon in the parts list (or hover over and press Y)
  • Matt_Shields
  • msandeep
    OK, I think I figured out how to do this - by selecting the extruded hub (in blue) and right-click and "make transparent". Then I can select the triangular region and use it for extrude.
