LOFT question
    NeilCooke Moderator, Onshape Employees Posts: 6,083 image
    Don't try to loft as a solid with an internal void - it won't work. Create a sketch on both side of just the external profile and loft (using "connections" to control any twist) then use the Shell command to hollow that section out.
  • luk_kuk
    luk_kuk Member Posts: 10 ✭✭
    Yes, this is it. Thank you.
