configuration variables in drawing
jr_vrvrkn
jr_vrvrkn Member Posts: 125 PRO
Hi,
Is there a way to display the variables that were used for a specific assembly configuration on the drawing? I know I can use Configured Assembly properties in the assembly file, but this would imply adding a property value for every possible combination of multiple variables, for the 12 options with several values I have in my assembly, This would be near impossible.
using featurescript I can set (a concatenation of) variables in a property field and display this in a title block or list, but obviously featurescript doesn't work on assemblies.
thanks.
  • tim_hess
    tim_hess Member Posts: 46 ✭✭
    Could you configure the text in a sketch and then display the sketch on the drawing?
  • jr_vrvrkn
    not sure. Can you explain? can you make a sketch in an assembly that references the configuration values?
