The "Favourites" drop-down opens with each click when drawing a sketch
botond_farkas
Member Posts: 2 ✭
Hey everyone!
After I "draw" a sketch, the browser's "Favourites" drop-down is opened, and I'm unable to even put in the dimensions of a rectangle.
What can I do/Which preferences should I change in order for the favourites drop-down not to be opened.
Thank you and br
Thank you and br
I can't imagine what's going on here, it's certainly nothing that Onshape is doing. What browser are you using and can you try a different one?Senior Director, Technical Services, EMEA0
I have exactly the same problem time to time. The browser is MS Edge, and sometimes when I open Onshape part studio or assembly window I start having Favourites dropdown menu rolling out, as if a hotkey combination was triggered.
As soon as I switch tabs, the problem goes away, and reappears when I return to Onshape tab. It does not happen often though, so hard to replicate, but it has been around for a year.
