Document never opens
stephen_sherwood846
stephen_sherwood846 Member Posts: 34 ✭✭
Hi, I designed a relatively simple model with a 130mm shaft. I used a script to add knurling to that shaft but it never finishes applying. When I try open open the model I get a please wait icon for several minutes and then an error "Onshape encountered a problem with your last operation. If the problem persists, please contact support. Support code 78911da8eaff11246c13a80a."
Is this something that can be salvaged or have I lost it?
