assembly degrees of freedom
jr_vrvrkn
jr_vrvrkn Member Posts: 125 PRO
Hello,
found this older post with no conclusive answer.
assembly degrees of freedom — Onshape
I have a  lot of (quite complex) assemblies with mates relative to a (virtual) origin point and the position of parts is depending of the mates of several other parts (mimicking the actual degrees of freedom in the real assembly) In the end everything should be fully constrained (but only by adding the last constrain this is achieved)
So, It would be very handy to see the degrees of freedom left to solve in the assembly...
If not, would this make an interesting feature request?
  • Bob_bob1
    Bob_bob1 Member Posts: 2 ✭
    Hi @stvn_vl, this is exaclty the feature I've been looking for in Onshape Assembly. It would be great to asses the numbers of degrees of freedom (DOFs) left in an assembly. For complex mechanism design this would be a great functionality.
  • jelte_steur_info
    did you look for an improvement request?
    if there isn't one, please write one so we can vote-up!
