Is it possible to delete sketch entities without deleting the sketch?
rens_berg
Member Posts: 2 ✭
I am construcitng circles between 1 points with coincidents to get their midpoint and radius and calculate if there are other entities within the circle.
After this evaluation, the circles are no longer needed. is it possible to delete them?
Hello Rens. You can click on any sketch element and hit the delete key. The Trim tool is another option. - Scotty
-2 -
Do you need to use the constraint solver to work out where the circle should go? Better if you can do it with math and then you don’t have excess geometry to delete.Alternatively you could solve, then get entities inside then delete the whole sketch.Senior Director, Technical Services, EMEA0
