Forum Discussion Format/Code does not work
hervé_pipon
hervé_pipon Member Posts: 60 ✭✭
Hello,
When I want to use Format/Code on the forum, it doesn't work.
See on https://forum.onshape.com/discussion/21555/skfitspline-and-bsplinecurve-controlpoints/
Find "test: same with code formatting" at the beginning
I'm using Chrome Version 115.0.5790.110
During Edit I see :
On the Forum it appears like this:
    S1mon Member Posts: 4,618 PRO
    It's very buggy and hard to use, but if you create an empty code block first, and then paste into that I think it works. Here's a random FS snippet:
    export function convertToMatrix(flatArray, uCount, vCount)
        var result = zeroMatrix(uCount, vCount);
        for (var i = 0; i < uCount; i += 1)
            for (var j = 0; j < vCount; j += 1)
                result[i][j] = flatArray[i * vCount + j];
        return result;
    Let's see if this works.
  • EvanReese
    EvanReese Member, Mentor Posts: 3,095 PRO
    It's definitely buggy. You shouldn't have to do this if it just worked, but you can click the top right button to toggle the html view and make sure it didn't add some extra stuff
  • hervé_pipon
    S1mon , I read a discussion on this way, and already test it : it doesn't improve.
    Evan_Reese I test different way , and the html view toggle doesn't change anything.
    For those who want to read the code it is not very pleasant without formatting. :(
    What's weird is that it displays correctly while editing.
  • EvanReese
    Test of paste, then convert to "code block" :
    <div>&nbsp; &nbsp; skFitSpline(sketch1, "spline1", {</div><div>&nbsp; &nbsp;&nbsp;"points" : [</div><div>&nbsp; &nbsp;&nbsp;vector( 0 , 0) * centimeter,</div><div>&nbsp; &nbsp;&nbsp;vector( 100, 100) * centimeter</div><div>&nbsp; &nbsp;&nbsp;],</div><div>&nbsp; &nbsp;&nbsp;"startDerivative" : vector(150 , 0) * centimeter,</div><div>&nbsp; &nbsp;&nbsp;"endDerivative" : vector(0 , 150) * centimeter,</div><div>&nbsp; &nbsp;&nbsp;});</div>
    Test of set to "code block" then paste:
  • EvanReese
    Yeah that didn't work...
  • hervé_pipon
    a few tests later ,
    When I write directly in the editor : it works normally  :)
    When I copy paste : it bugs  :(
    When I write a simple line of code , and I inspect it inside the code tag the text is:
    <pre class="CodeBlock"><code>skFitSpline(sketch1, "spline1", {
    "points" : [</code></pre>
    After a copy paste the text is:
    <pre class="CodeBlock"><code><div>skFitSpline(sketch1, "spline1", {</div><div>"points" : [</div></code></pre>
    I seems that some <div> tag where added : I don't know if it is the editor who change the behaviour ?
  • hervé_pipon
    If I copy paste from a correctly formatted code on the forum, it works fine  :)
  • hervé_pipon
    To make it to work,
    you effectivly have to leave the HTML mode
    --  Once in text mode, you can copy the code; disregard existing text that is no longer properly formatted
    --  Go back to HTML mode
    --  Select the pasted code, which is not displayed correctly, but it does not matter
    --  Apply the Code tag
    Everything is back to normal  :)
    not very user friendly
  • TillysInteriors
    TillysInteriors Member Posts: 15 PRO
    It looks like HTML mode has been removed from the latest forum editor, so this doesn't work any more 😕
