Improvements to Onshape - August 11th, 2023
cody_armstrong
Moderator, Onshape Employees, Developers, csevp Posts: 229
The non-stop cadence of improvements continues with another big update. It includes a long list of core improvements, so we hope you are as enthusiastic as we are. Let's dig in!
GENERAL IMPROVEMENTS
SET DEFAULT ROTATION BEHAVIOR
You can now set the default rotation to a constrained behavior. In the past, constrained rotation required holding down the Alt key.CURVE PATTERN IMPROVEMENTS
You can now define a Curve pattern by distance between instances.EXPLODE LINE IMPROVEMENTS
You can now hide (or show) all explode lines at once by right-clicking the Exploded view in the Exploded view panel.STANDARD CONTENT AUTHORING PERMISSIONS
Onshape Professional administrators will find a new authoring permission to control who in the company is allowed to edit Standard content.
RENAME DISPLAY STATES
You can now rename Display states.
STANDARD CONTENT PROPERTY IMPROVEMENTS
Individuals using the Onshape Free, Standard, or Education plans can now edit Standard content properties. In the past, this was limited to companies using Onshape Professional or Enterprise.DRAWING IMPROVEMENTS
CENTERMARK IMPROVEMENTS
You can now apply Centermarks to holes that are not normal to the view direction.
IMPROVEMENTS TO DRAWING VIEWS WITH FAULTY GEOMETRY
Faulty imported parts are now ignored by default when creating drawing views. You can also now choose to hide (or show) faulty imported geometry in assembly drawing views. Hiding faulty parts in drawing views can substantially improve performance.
RELEASE MANAGEMENT
SAVE RELEASE CANDIDATE DRAFTS
You can now save draft release candidates so that they can be completed later. This means big release candidates do not need to be created and submitted all at once.ENTERPRISE IMPROVEMENTS
UNPUBLISH CUSTOM WORKFLOWS
Onshape Enterprise Adminstrators now have an option to "Unpublish" workflows. This makes it easy for administrators to hide workflows that are no longer used. Unpublishing will not impact released or pending Release candidates using that workflow. This change only impacts new releases.
Please take a moment to try out these new features and improvements and leave your comments below. For a detailed list of all the changes in this update, please see the changelog.
Remember: The updates listed here are now live for all users when creating new Documents. Over the next few days, these features will also be available in Documents created before this update.6
Love it! I've been wanting this for sometime but have always been distracted and never got an improvement request in. When working on a large release, the candidate is usually so laggy and sometimes, the browser view will suddenly require a refresh. Will be great to be able to save while editing it to avoid lost work.9 -
Great list of improvements! Thankyou. Save release will be handy3
I really like the little fastened to origin icon.
2 -
Two very nice quality-of-life updates: release candidate drafts and renaming display states. Maybe now I'll actually use display states
3 -
The most perfect update for my 30th Birthday! NON Default Turntable rotation was literally what threw me off Onshape to begin with. Thank Goodness I came back!6
WOW...0
Save release candidates is a huge one. If you get it kicked back, redoing everything is a huge pain. It could be such a minor fix and then you'd have to go through all that twice.2
I Haven't tried the save option yet...michael_zeagler said:Save release candidates is a huge one. If you get it kicked back, redoing everything is a huge pain. It could be such a minor fix and then you'd have to go through all that twice.
Note that you already had the option to "clone" a rejected release (to avoid re-creating everything from scratch):
- go to the version you wan to release
- right click (not left) on the rejected release in the version tree and then go to that release and pick "clone"3 -
Oh that's new, I haven't used professional in at least a year. That's great.1
These are some great changes!
Do y'all have any updates on when Cloudmilling CAM will roll out? Or any more details about how it'll work?2 -
"You can now apply Centermarks to holes that are not normal to the view direction. " only works for actual hole features? not cilindrical faces?
and thanks for the excellent update (as usual)!
Curve pattern. 👀
So now that we can save release candidates, can we keep working on the drawings until it's out of draft state and the changes be reflected in the RC?0
Release drafts refer to the current workspace so you can make as many changes as you like before submitting the RC.Matthew said:So now that we can save release candidates, can we keep working on the drawings until it's out of draft state and the changes be reflected in the RC?Senior Director, Technical Services, EMEA1 -
@david_riedell, as a rule we don't talk about release dates for upcoming functionality. We do realize how important CAM functionality is to our customers and we're just as excited as you are to get it released.John Rousseau / VP, Technical Operations / Onshape Inc.2
Un saludo,
Partner de PTC - Onshape Averigua a quién conocemos en común2 -
Hoping that the next update we will see the new sheet metal loft functionality...... crossing fingers and toes!!!!!
1 -
Sheet metal loft would be great! This is the only reason why I have to use traditional CAD Software
1 -
Great improvements! Rename Display state and Center mark are the best...1
3
https://youtu.be/N5k2D4db9Rs
