How to change Onshape Region
don_b
don_b Member Posts: 169 ✭✭
edited September 2023 in Community Support
I have long latency and from the east coast am on us-west-2 with better latency in ca-central-1 (Central) or us-east-1 (Virginia) or us-east-2 (Ohio)
How do I change to a different location
    us-west-2 is your closest region. What latency values is Onshape reporting and what are you experiencing that makes you think latency is the problem?
  • don_b
    used the tool 78 vs 19 Virginia or Ohio much closer
    l have slowed regens
    Onshape's performance tool? 78ms is fine and has no effect on regen time. Take a look at the regen times button in the top right corner of the feature list to see where the bottleneck is. Also, how many features in your feature list?
  • don_b
    doing everything I can to speed it up..... I have obviously too many derived but geometry requires it
    simple question... how do I change regions
    I refer to my previous answers - "us-west-2 is your closest region" - "has no effect on regen time" - chaining workspace derived features is a sure way to bog things down - swap to versions instead or use in-context.
