Tilt on extrusion
sergi_santos
Member Posts: 4 ✭
Hi,
I'm having a problem trying to make some sort of tilted extrusion for a helix. If you have access to my files it's the file called Bogeria HC.
I found a topic about the same issue where they seem to resolve it but the link is corrupt:
@sergi_santos, doing a smooth surface is relatively straight forward which would involve sweeping a blade profile sketch along a helix. Adding the wavy texture will be a few more steps.
This should get you started in the right direction with the wavy and tapered blades. Note that this doesn't cover the reverse waves between the waves; which is possible, but would quite a few more sketches, sweeps, and patterns.
https://cad.onshape.com/documents/5ca3c53fed2db22e228e842e/w/889dc61e2f16d26024a5b4be/e/f56ea7c7ffbbe8ddbe70d...
◉ RENDERCAD - Photorealistic product rendering.◉ CADSharp - Professional CAD + software consulting.
▚▞▚▞▚▞▚▞▚1
You will need to make your file "Public" and post a link to it here for other users to find it.
See this link for details:
https://forum.onshape.com/discussion/9107/forum-post-checklist-read-this-first#latest
Here is the link:
https://cad.onshape.com/documents/4d14505c5a0e7ccf1aff0a24/w/fedfadc18baeddf4c9b52871/e/17bf330970092dde91e19243
you can see a snapshot of the file I'm making, I can just extrude it vertically or let's say at a 90º angle:
I would like to make an extrusion tilted at an "x" angle.
Here you can see another similar project that I found on the internet where you can see the kind of extrusion that I'm looking for:
If you also know how these wavy walls were made that would be nice to learn too.
▚▞▚▞▚▞▚▞▚1
