<p>Welcome to the Onshape forum! Ask questions and join in the discussions about everything Onshape.</p></p><strong>First time visiting? Here are some places to start:</strong></p><ol style="list-style:inherit;margin-left:25px;"><li>Looking for a certain topic? Check out the <a href="https://forum.onshape.com/categories">categories filter</a> or use Search (upper right).</li><li>Need support? <a href="https://forum.onshape.com/post/question/community-support">Ask a question</a> to our <a href="https://forum.onshape.com/categories/community-support">Community Support</a> category.</li><li>Please submit support tickets for bugs but you can request improvements in the <a href="https://forum.onshape.com/categories/product-feedback">Product Feedback category</a>.</li><li>Be respectful, on topic and if you see a problem, Flag it.</li></ol><p>If you would like to contact our Community Manager personally, feel free to <a href="https://forum.onshape.com/profile/6/LouGallo">send a private message</a> or <a href="mailto:lgallo@onshape.com">an email</a>.
</p>
</p>
Importing an STL part inside the current document
emmanuel_chappat
Member Posts: 4 ✭
I have a working document, to which I would like to import an STL part.
The onshape documentation on the topic seems to be outdated :https://cad.onshape.com/help/Content/uploadfiles.htm#Importin3. When I click on the + import button, the import modal does not show a "Import to this document" options
How does one go about this?
Thanks a lot
Derived featureSenior Director, Technical Services, EMEA2
Select '+' from lower left of screen. Import is the last item in the list. If it's not showing up, try refreshing the browser and if it still isn't there then contact support since it should be there.
glen_dewsbury said:Select '+' from lower left of screen. Import is the last item in the list. If it's not showing up, try refreshing the browser and if it still isn't there then contact support since it should be there.
Thanks Glen, I do see the import button, but importing will create a new Part tab and I can not find a way to bring that part inside my current model. Is there a way to do that ?glen_dewsbury said:Select '+' from lower left of screen. Import is the last item in the list. If it's not showing up, try refreshing the browser and if it still isn't there then contact support since it should be there.
