Why is my OnShape so slow? (Browser is not running at 60 frames per second)
My OnShape suddenly became extremely slow when interacting with the server. what can be done to fix this
    FPS is determined by your local graphics card, so the bigger the assembly on screen the slower it (may) go. Check you are using the right graphics card for your browser at https://cad.onshape.com/check
  • benjamin_mcrae
    benjamin_mcrae Member Posts: 5 EDU
    im running a 2060 and at the check page my computer registered off the charts in the graphic department. I guess the issue im having is whenever I try to go throught menus or import part studios or assemblies of export a part or drawing it takes forever an example is it took 5 minutues to open the dialogue box to export an stl and another 3 to actually acheive export
  • dirk_van_der_vaart
    dirk_van_der_vaart Member Posts: 561 ✭✭✭
    And your Browser is compatable with Onshape ??
