Steps/Second
bryan_erickson118
Member Posts: 2 ✭
Greetings,
Hopefully someone in the verse sees this that knows the answer. I've looked through Onshape Help and cannot find the coloration between step numbers and time. I.e., I'm animating a rotating item and in order for it to flow correctly I have to set it to 720 and loop it. I want to have a specific revs/second but have not been able to determine the number of steps needed to get a specific revolution speed. Anyone on here know the factional second per step? Also, is that number identical for linear motion? I have ran timed experiments and determined that it is a linear function, but between human error and server lag time, I cannot get it precise enough to be useful.
I'm assuming that it doesn't have to be a precise speed? just set it to 1000 and if its too fast turn it down.
There is no time associated with this - it depends how good your graphics card is.Senior Director, Technical Services, EMEA0
