How do I update the parts in a render studio if I've made changes to my design?
dave_franchino
Member Posts: 78 ✭✭
Hey folks,
I created a render studio scene from an assembly in onshape - I've added a few new parts to my assembly but I can't figure out how to update the scene. It still reflects the state of my assembly when I created it. Is there a way to preserve materials and settings and update a scene if the underlying assembly or part studio has changed?
Yes! From the scenes screen (where you choose which scene to open) there is a menu on the right. Click on that and there is an update option.Senior Director, Technical Services, EMEA0
Thanks so much @NeilCooke! Had a hard time finding it. Another quick rendering question. When I add an environment I've found it's scale doesn't match my intent. For example I'm trying to render a large (2 meter) product into an outdoor scene but the environment is opening as if it's expecting a 200mm product. When I zoom, Onshape is scaling my product, not the environment so to get the two to match I've zoomed in so close much of my product is off the screen. Is there a way to scale the environment as opposed to the geometry in the scene??2
Has the answer to this original question changed?
I have a scene list on the left of the work area and a scene tab (for editing the scene) on the right side of the work area
But I don't see a menu with an update option. Can you maybe send a screenshot?0 -
Yes it appears to have changed. I believe you need to release a version of the linked assembly/part studio. Then you can right click the render studio tab and select "update linked document."
