Bubble Text or soft edges for text
Is there a way to create this effect on onshape where the letters are bubble shaped or the edges are soft?
  • martin_kopplow
    martin_kopplow Member Posts: 1,627 PRO
    Yes. Create a sketch with the text center lines on a plane with an offset from a body's face. Then remove-sweep a circular cross-section of the letters along the centerlines, set body a s target. The radius of the circular profiles must be greater than the sketch plane offset. Done.
