Variables within Configuration - HELP!
brian_fischer804
Member Posts: 2 ✭
Lets say I have a box, and the box is defined by L x W x H... I originally made these variables so I can adjust as I needed on the fly with the variable table. But what I didn't realize is if I changed the variable in another part studio, it would change the dimension in every part studio.
Since I am trying to have 4 different size boxes... and the ability to switch between the 4, as well as manipulate each as I prototype add on features... I knew I needed to learn configurations. So I watched the tutorials in Onshape.
I configured all my dimensions within the parts table that I wanted to have the ability to change. However I realized that is not exactly what I wanted. At least I do not think (I am very confused at this point since like I feel like I am in the movie inception).
I think I would like to have the variables editable within my configuration table. I do not like that the column header for the dimension is called "Distance" I would like it to be "Width" for instance & "Height" which would also be the name of the variable (#Width, #Height etc.)
When I watch the tutorial on the Onshape , specifically on how to setup configuration table, I saw the lady teacher setup the column headers as variables. They did not say "Distance" they said "ID" & "OD".... But I did everything she did to the best of my ability, and they still say distance! She did not go into depth, at least on that portion of the video (maybe towards the end, I will still be watching these as I wait for a response to hopefully answer me own Question.
Any help would be greatly appreciated.
Hi Brian. Thanks for the thoughtful and thorough question. And good job going to the Learning Center to try to figure it out. I think you're close. For starters, let me know if this is what you are trying to accomplish:
https://cad.onshape.com/documents/9a358b8d6754ef1c149cc597/w/56be5392f15d79a73d0bf148/e/3bf8b77fdc9c93413b1a6285
Thanks,
Matt0
