Extruting from two sketch shapes that touch each other in a single point.
mathias_wulff
mathias_wulff Member Posts: 8 ✭
edited January 2016 in Community Support
Im making ventilation in a back plate for some 3d printed casing. Instead of having just boring circular holes I went creative.
I found a sketch pattern that I liked but cant get my head around why I cant extrude when the areas that I select for extruding touch each other in a point.
I have tried to make the most simple version of the problem here: https://cad.onshape.com/documents/c2f452a72eb640059ca141a2/w/ebc862d2206b456984bfa9f4
At the demo you see two eyes/holes that are not touching. In the sketch there is a 3rd eye/hole in the middle, but If I select that to be part of the selection of "Extrude holes" then no material gets removed.
Any inputs?
  • shanshan
    shanshan Member Posts: 147 ✭✭✭
    we could not extrude the sketch shape what you described,because there is a intersection point between two holes,so when extrude them , could not deal with these intersection points
  • mathias_wulff
    For others in the same situation: have a look at https://forum.onshape.com/discussion/comment/13213/#Comment_13213
