Extrude through all does not stop at the end of the part
terry_milam
Posts: 9 ✭
When I extrude this rounded edge with the through all option
it doesn't stop at the curve but does stop about 16mm later for some reason. I
can choose blind and stop it at the far edge of the curve but that leaves me
with a long edge on the curve I have to trim off manually when I print
this. Any ideas? Thanks
Through all goes something like 500 mm. I think you are looking for "Up to face."0
That would be the blue box asking you to select a face.Senior Director, Technical Services, EMEA2
Trough all works but doesn't stop at the end of the part
Up to face doesn't extrude at all unless there is an additional setting I'm not putting in.
Thank you so much Neil! Figured I was just overlooking the obvious0
