Error in Onshape Course
Grav_electric
Member Posts: 20 ✭
I was following the Introduction to Sketching course in Onshape, I was on the last part to finish section 4, Intermediate Sketching, when I was on slide 7, about the measurements, I think the measurements on the slide are false, because I have tried several ways, and come to the same spot, where all of the sketch is red. Is it me or the Course?
A link to your document is needed. - Scotty0
If your sketch is red then you've introduced an error somewhere, likely a constraint that was automatically inferred.Senior Director, Technical Services, EMEA1
I think this usually happens due to an accidental vertical constraint due to the top and bottom points of the arc.0
