TAB manager is a long stretch
brucebartlettbrucebartlett Member, OS Professional, Mentor, User Group Leader Posts: 2,148 PRO
I find the tab manager a long stretch when changing from the revision tree and back. I know I can use the alt t but it would feel better if it was up the top instead of by itself down the bottom. Does anyone else find this or is there a good reason it's down the bottom?
  • eric_pestyeric_pesty Member, pcbaevp Posts: 2,497 PRO
    I'm guessing it was put at the bottom as one case when you might want to bring it up would be when you are looking for a tab at the bottom...
    But I agree that closer to the version tree would be better as I also change back and forth quite a bit!
  • S1monS1mon Member Posts: 3,844 PRO
    Yep. It bugs me every time I click down there. Despite Fitt's law, it's awkward to go from the other side panels buttons to the tab manager.
