FeatureScript for Intersection Curve
graham_lock
Member Posts: 277 PRO
Hi all,
I want to include an intersection curve in my FeatureScript but I'm struggling to find the correct function.
I've found opIntersectFaces but that takes 2 arrays of faces.
I want to pass a plane and a curve?
Any help appreciated.
Thank you.
Thank you.
If you want the point where the curve passes through the plane use evDistanceSenior Director, Technical Services, EMEA0
What I'm looking to do is move 'Intersection curve 1' functionality into my FS
https://cad.onshape.com/documents/eaa6d4e47c2370e130af99ef/w/5d494f6fad19ead9b96f9ac0/e/d0378f5dd7633206768a4b14
I've got as far as:
intersectionCurve(context, id + "intersectionCurve", { "group1" : qUnion([definition.refEntity]), "group2" : qUnion([definition.skin]) });
What input filter do I need to capture a surface for the Skin Entity parameter?
Thank you.0 -
Got there
"Filter" : EntityType.BODY && BodyType.SHEET
