The Red
henry_feldman
Member Posts: 131 EDU
So, a very frustrating thing in OnShape is "the red". And what do I mean by that? Well, that when you do some operation (in this example a sweep) that the title turning red indicates that something is wrong, but there is no message or other indicator to tell you what the issue is.
Well WTF is wrong? No option is red to indicate what the problem is. There is no error message anywhere on the screen, just the red title. So I have no idea what to correct here. I've done this identical operation to 3 other extruded pins and it all worked fine, but this one, red? See, if it told me (that pin can't be used because it is a sunday or whatever) I would know how to correct it...
