Error code: SIGILL i
poyraz_kaya
poyraz_kaya Member Posts: 6 ✭
When I try to design something on Onshape, my browser suddenly gives the error code: SIGILL. When I refresh the page, I can use it a little bit more, but within 5 minutes, I get the same error again.
    NeilCooke Moderator, Onshape Employees Posts: 6,113 image
    That's a new one for Onshape. What operating system / version, browser / version are you using? Is everything up to date? Do you have any browser extensions running?
    S1mon Member Posts: 4,564 PRO
    Apparently this could be from a Linux system.
    SIGILL = "Signal: Illegal Instruction." This error occurs when a program tries to execute an invalid, illegal, or undefined machine language instruction, typically due to corrupted code, a bug, or an attempt to run code on incompatible hardware.
  • poyraz_kaya
    i use latest manjero version with latest chromium version
  • poyraz_kaya
    I don’t understand. I’m new to Onshape, and in the quick start guide video, they said that if your computer can run a browser, you can use Onshape. So why is my hardware incompatible
    edited August 2024
    What does https://cad.onshape.com/check say? Also check another browser like Firefox. If the browser is raising an exception against the operating system there's not a lot we can do and the fact that you can use Onshape at all points to it being the distro.
  • poyraz_kaya
    The site said that it is compatible.
    The only thing we send to the browser is a webpage, so there is something going on between your browser and operating system. Did you try a different browser?
  • sher1ock
    sher1ock Member Posts: 2 EDU
    I get this problem constantly on ubuntu 24 with any chrome based browser.
