FeatureScript request: Corner fillet for CNC machining
kvdmolenp
kvdmolenp Member Posts: 28 ✭✭
edited September 2024 in FeatureScript
When machining a part with a CNC mill, sharp corners cannot be milled (due to the diameter of the drill, this actually also holds for lasercutting).
The trick is to create a "deeper" radius with the same size of the drill (slightly larger), see below.
But it's a drag to draw these over and over..
Is there perhaps an existing featurescript to add this to a 3D corner, similar to a fillet? Or perhaps directly in the drawing, but I'd prefer for 3D fillets due to the maintainability of the drawing.
PS, I am aware of the SuperDerived featurescript, and using that in combination with a configurable sketch and extrusions, but that still is a lot of work.
Thanks!
  • Matt_Shields
    The Laser Joint custom feature has this feature. Maybe recycle some of that code?
  • eric_pesty
    Have you tried the "corner overcut" FS:
    https://cad.onshape.com/documents/b99915c0b73924ca981bc57f/v/615cb6d9633a595a6bc99f8a/e/14458d1263a98640a0cf663c
  • kvdmolenp
    The "corner overcut" is exactly what I was looking for, thanks!
    I didn't know the name, so thanks, als for the Laser Joint tip.
